Service Pack
OpticStudio 21.1.2 Release Notes
Allie
  • 343 replies
Released: March 16th, 2021
OpticStudio 21.1.2 contains the following fixes and enhancements.
Performance & Stability
  • Tolerancing – Parabolic and normal distributions for the radial tolerance operands (TSDR, TEDR, TARR, TRLR) are now centered around the nominal value. Previously these were centered around (Max+Min)/2.
Bugs
  • Detector Viewer – Text tab now correctly shows data for all detectors in the system when Summarize All is selected. Previously, data for only one detector was displayed.
  • Multi-Configuration Editor – IGNM operand now correctly includes the selected Last Surface. Previously a comment on this surface in the Lens Data Editor could cause it to be incorrectly excluded from the operand.
