Tilted Mirror and lens in sequential mode
HI everyone.
Im trying to make a system which uses mirror reflect. However when I tilted the lens after the mirror, it is not possible. How can I fixed this problem?
Thanks in advance
Best answer by David
Hello Tran,
I suggest you re-work your design using the Add Fold Mirror tool rather than Tilted surface types. (Look this up in the Help system.) Also remember that thicknesses after a mirror must be negated.
This article might help. How to model a scanning mirror
Kind regards,
  • 337 replies
  • June 20, 2021
Hello Tran,
Kind regards,
  • June 21, 2021
I made it, thanks so much :D
