I am doing some trials with a laser scanning setup. These are just preliminary, I still need to insert the right collimating lens, focusing lens and beam expander later. But is was trying to position the 'moving lens' to get the smalles spot size (image at focus), but from the lay outs, it seems the focus is a bit in front of the image plane. Is there another way to do this optimization? Or is this the right result?
Edit: My bad, this is probably just the spherical abberation that is out of whack.
Also, how can I best model the input laser beam? It will be a singlemode fiber with a 25µm core. Now I did it via object space NA number.
