Simulating a multilayer mirror in OpticStudio
  • November 8, 2021
  • 272 views
Louis.M
I am trying to simulate a  mirror in non-sequential mode that has a wavelength- and an angle dependent reflectance as shown in the attached files.
I have already tried to do this by defining a surface coating with the refractive indices of the two different elements but this has not worked out well.
I would be thankful to know if this is possible in OpticStudio
Best answer by David
A Table Coating can be used to define an arbitrary coating with properties that depend on both wavelength and angle.
Edit: You can find a discussion of Table Coatings in this article: How to model a dichroic beam splitter.
  • November 8, 2021
