How to change the PSF display size from Zemax API?
  • December 21, 2023
  • 170 views
Pascal Gregoire
I am using the python API to generate and save FFT PSFs. I can change all the parameters using the python API (with the ModifySettings function) appart the display size. How can I do it? It is not listed in the documentation for the Zemax macro.
Best answer by Pascal Gregoire
Many thanks! I could not find in your documentation the trick to make it work (using __implementation__), I’ll get rid of MODIFYSETTING.
  • 1115 replies
  • December 22, 2023
@Pascal Gregoire,
If the MODIFYSETTINGS doesn’t have the setting which you’d like, it is likely that it hasn’t been implemented.
However, the settings of the FFT PSF have been fully implemented in the ZOSAPI. This means you don’t need to rely on MODIFYSETTINGS anymore.
Here is a Python example:
from ZOSAPI.Analysis.Settings import Psf
# Open a new FFT PSF analysis
fftPsf = TheSystem.Analyses.New_FftPsf()
# Retrieve the settings
fftPsfSettings = fftPsf.GetSettings().__implementation__
# Change the sampling
fftPsfSettings.SampleSize = Psf.PsfSampling.PsfS_1024x1024 # Sampling
fftPsfSettings.OutputSize = Psf.PsfSampling.PsfS_1024x1024 # Display
# Apply settings and run analysis
fftPsf.ApplyAndWaitForCompletion()
Pay attention to the __implementation__ after calling GetSettings(), this relates to this issue:
The rest of the settings are found in the ZOS-API Syntax Help File:
And this is the list of available sampling sizes:
Next time you work with an analysis in the ZOS-API, you can use the property:
HasAnalysisSpecificSettings
to check whether said analysis has been fully implemented in the ZOS-API, i.e. it doesn’t need a settings file anymore.
For example:
# Test is analysis has its settings implemented
print(fftPsf.HasAnalysisSpecificSettings)
which should print a True value.
Let me know if that answers your question and take care,
Pascal Gregoire
  • December 22, 2023
