Optimization absolute borders
  • February 7, 2022
  • 369 views
fabian358
Hi everyone,
Is there a way to give a radius variable a range of possible values that can never be crossed? As I understand I can give operands CVLT and CVGT to make the range (e.g. for values between 5 and 15 mm I need, as I understand, CVGT with target on 1/15 and CVLT with target on 1/5 if lens units are millimetres) but sometimes they go beyond the range and I don’t really know how to prevent the optimization from doing it.
Thank you for help,
Fabian
Best answer by Jeff.Wilde
Try simply increasing the weight values of the operands.
Or, if necessary, you can use a negative weight that causes the operand to function as a Lagrangian multiplier
  • 510 replies
  • February 7, 2022
