Record GUI interaction as ZPL commands?
  • September 20, 2023
  • 112 views
Michael.Young
I was helping a colleague with ZPL the other day. He wanted to know how to set a field as a variable and then constrain it. Additionally, he wanted to do this through a ZPL.
The first part is easy enough. My approach was to expose the field as a variable through the multi-configuration editor using “YFIE”, declaring the solve as “Variable” and then constraining it in the merit function editor with “MCOL”, “MCOG”, or “MCOV”.
For the ZPL portion, I wrote a small script for him demonstrating how to assign a variable in the MCE with ZPL.
CLOSEWINDOW
! INSERTMCO, 1					# insert a row into the mce.
SETMCOPERAND 1, 0, "YFIE", 0 	# changes the operand to "YFIE"
SETMCOPERAND 1, 0, 1, 1			# assigns YFIE to field no. 1
SETMCOPERAND 1, 1, 15, 0		# changes the value of row 1 config 1 to 15
SETMCOPERAND 1, 1, 1, 3			# changes the solve type to "V"
BEEP
This made me think that it would be useful if there were a way to record GUI interactions as lines in a ZPL. For example, I could turn on the proposed feature and a text window would open in the background. When I click on row 1 of the multi-configuration editor and press “insert” a line would appear in the text editor “INSERTMCO, 1”. Once I have completed my task, I would turn off the feature, review the text file and could use it as reference for writing my own ZPL.
I realize that this is easy to conceptualize but perhaps difficult to implement. I didn’t see anything in the help file that resembled this idea. It there a way to do this with Zemax currently? If not, it would be useful as a feature request.
I’m quite sure OpticStudio doesn’t have this feature, and I like the idea.
I know that ImageJ (or Fiji) has a macro language as well, and I’ve used their macro recorder countless times, see this as an example.
I imagine it must not be easy to implement though.
  • 1134 replies
  • September 21, 2023
Michael.Young
  • 42 replies
Hi @David.Nguyen ,
Thank you for the reply. The comparison to ImageJ is apropos and the best example that I could think of to offer the Zemax team.
For reference, here is a link to ImageJ’s recorder function,
ImageJ Recorder
Sincerely,
Michael
