How to Install Zemax on a different hard drive other than C:\?
LaserEd
When I run the install for Zemax there is no option to choose a location. It defaults to the C drive with no way to change that...as far as I can tell. My C drive is near full. My D drive is near empty. How do I install on the D drive?
I tried moving the install files to the D drive and run the install from there but it continued to put the files in C where I don't have enough space.. Short of installing a bigger C drive and reinstalling all my programs...etc what can I do?
Thanks for the help and all the best,
Best answer by LaserEd
There is an options tab next to the install tab to select the location of the installation.
LaserEd
  • October 5, 2023
Hi all!
Note that the “options” button at the beginning of the setup process is only in the Ansys version of Opticstudio; Legacy Zemax releases will ask for an install location along the way.
