Rotation of off-axis mirror
  • October 6, 2022
  • 282 views
Hi, I have been trying to rotate an off-axis mirror along the mirror surface axis (Geometric axis of the mirror).
I have created an off-axis mirror in the sequential mode by decentering. When I tilt the mirror, it only rotate along the vertex of the parabola.
I also tried to converted to NSC parts. However, it also rotate along the parabola vertex. I tried to created some coordinate to move the mirror to where the geometric center is, but it is quite messy. Is there any better way to do it?
Thanks a lot.
Best answer by Mark.Nicholson
Check out the off-axis conic freeform surface, and this article:
