ZPL language question
  • May 31, 2021
  • 413 views
Hi
This Shayne from Clouldight, Vincent's colleague.
I would like to know how to use operand of ZPL 'SPRO' . Is it same as SETSURFACEPROPERTY, SURP?
Thanks!
Sincerely,
Shayne
Thanks for your question here on the MyZemax forums!
SPRO() is a numeric macro function, so it will return the surface properties, but it will not make any changes.
In order to pull the surface property you are interested in, you will need to input the surface number and the code for the specific surface property:
The codes for the surface properties are same as for the SETSURFACEPROPERTY keyword.
The difference is that SETSURFACEPROPERTY is a keyword, which means it will not only report the value, but it will make changes to the system.
You may read more about the differences of functions and keywords in this kowledgebase article:
Introduction to Zemax Programming Language (ZPL) · MyZemax
I hope this helps, but if you have any further questions, please do not hesitate to ask!
Csilla
Csilla Timar-Fulep
Csilla
