Hii All , How can I find out m square for final beam of multi configuation system ? POPD gives us the value for only one configuation. Right ?
M square for multi configuration system
You can save the ZBF for each configuration here:
The ZBF files will be saved under {Zemax}\POP\BeamFiles.
Then you can write a macro that will add them. I have attached the macro in my previous post. It needs to be copied under {Zemax}\Macros. But here is a screenshot of the code:
