Reding data from .dat-file into ZPL macro
  • February 1, 2022
  • 685 views
I would like to read several numeric data as well as text data from a .dat-file into a zpl macro to use some of them for further use.
For example, the .dat file has 5 rows and 3 lines, divided by Tabs, e.g.:
Pos1    3.7   4.2   6.2   8.7
Pos2    9.0   7.5   2.8   5.6
Pos3    0.5   1.8   4.6   4.3
Is it possible to use the READ command for reading the complete .dat-file and to select afterwards some special data for further optimization?
Or would it be possible to read only some special data from the .dat-file for further use, e.g. (Row2, Line 2 = 9.0) and (Row3, Line 3 =1.8)?
Best regards
Ralf
Best answer by Jeff.Wilde
It’s easier to read just numeric data, but reading mixed string and numeric values is certainly very doable.  Here’s an example using your data set.
! read data from file
numrows = 3
numcols = 5
DECLARE DARRAY, DOUBLE, 2, numrows, numcols
! read numeric data (note: strings are set to zero)
OPEN "test.dat"
FOR i, 1, numrows, 1
	FOR j, 1, numcols, 1
		READNEXT x
		DARRAY(i,j) = x
	NEXT j
NEXT i
CLOSE
! print results
		PRINT DARRAY(i,j)
	NEXT j
NEXT i
! read strings from first part of each line
OPEN "test.dat"
READSTRING ROW1$
P1$ = $GETSTRING(ROW1$, 1)
READSTRING ROW2$
P2$ = $GETSTRING(ROW2$, 1)
READSTRING ROW3$
P3$ = $GETSTRING(ROW3$, 1)
CLOSE
PRINT P1$, "  ", DARRAY(1,2), "  ", DARRAY(1,3), "  ", DARRAY(1,4), "  ", DARRAY(1,5)
PRINT P2$, "  ", DARRAY(2,2), "  ", DARRAY(2,3), "  ", DARRAY(2,4), "  ", DARRAY(2,5)
PRINT P3$, "  ", DARRAY(3,2), "  ", DARRAY(3,3), "  ", DARRAY(3,4), "  ", DARRAY(3,5)
Here’s the output:
The ZPL keywords:  READ, READNEXT, READSKIP, & READSTRING offer various methods for getting data from files into the ZPL shell.
  • 510 replies
  • February 2, 2022
numrows = 3
numcols = 5
OPEN "test.dat"
		READNEXT x
		DARRAY(i,j) = x
	NEXT j
NEXT i
CLOSE
! print results
		PRINT DARRAY(i,j)
	NEXT j
NEXT i
OPEN "test.dat"
READSTRING ROW1$
READSTRING ROW2$
READSTRING ROW3$
CLOSE
Here’s the output:
  • February 4, 2022
Hi Jeff,
thanks a lot for your detailed description. That was very helpfull to me.
