Hello! How to add to my NSC design a silicon detector response curve for Color Detector? Maybe simply add a “thin filter” at the top of the detector area having this spectral characteristic, is it appropriate? Or maybe to add different weights for, e.g., 10 wavelengths based on detector response curve. Thanks
Best answer by Mark.Nicholson
Your first suggestion sounds right. Define a TABLE coating with a transmission vs wavelength set by the response curve of the detector, and apply it to the image surface.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
