How to model fiber optic bundle
  • February 8, 2020
  • 274 views
John.Hygelund
I need to model a light guide made of 9000, 50um fibers arranged in a circle. What is the best way to model this? Is there a pattern feature? Or is my best bet to model the geometry in 3d cad and import it? Assigning the material properties for all the fibers seems like a nightmare. Any advice would be greatly appreciated.
Alissa Wilczynski
You could make use of the source array capability in non-sequential mode. Within the properties for your source object (which would be a single fiber), you would use one of the array settings as shown below.
The settings are then controlled on a single line/object and duplicated across the entire array. So if you were to trace 100 rays against the parent source, you would get 100 rays from each of your 9000 fibers.
John.Hygelund
  • 71 replies
  • February 23, 2020
Thank you. I found this post on array ring that was particularly helpful.
https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01427
