Is there any error handling in the STAR LOAD FEA data tool?
  • July 15, 2021
  • 67 views
Hui Chen
When using the Load FEA data tool to load data into OpticStudio, if the FEA data format does not meet the requirement, will user receive an error or warning?
Hui Chen
  • 144 replies
  • July 15, 2021
As explained in the help file at The STAR Tab > FEA Data Group > Load FEA Data, the FEA data need to be arranged in following format.
The structural deformation data has six columns and the temperature data has four columns. If the data is missing a column or not tab delimited as required, user will receive an error.
