Replace a stock lens
  • September 2, 2020
  • 134 views
Hello from a new user here:
Is there a way to easily replace a lens in the optical system? I could not find a relevant info in the forum.
 For example, when you've already inserted a doublet lens A into the system, but want to change it to B (both are in the catalog). Is there a simple way to switch the surfaces without deleting and inserting a new one?
Thank you for your time.
Sorry, you have to insert the new and then delete the old, or vice versa.
