API (CS User Extension): Fiber Laser Calculator
  • May 12, 2022
  • 304 views
This Zemax User-Extension helps set-up or check a system with fibers or lasers in OpticStudio. There are two tabs: one to set-up correctly the System Explorer given the fiber values and a second tab to check that a system has been set-up correctly. Values are also given for POP.
Click here to download
2020-05-13 1.0 - Creation
Mayank1298
  • 5 replies
  • June 26, 2023
Works!
