How To Edit Coordinate Breaks in Matlab API
  • July 9, 2020
  • 271 views
Stephen.Chapman
In the ZOS-API example, when they tilt/decenter a system, they do it by changing the surface properties. I know how to insert coordinate breaks using the Standalone API, but I haven't been able to find resources on how to edit the parameters (decenter/tilt) of these coordinate breaks. A link to some documentation would be great.
Thanks
Hello Stephen,
Please check out Example 07: Tilt and Decenter Elements under Programming / ZOS-API Help / ZOS-API Syntax Help / Examples:
The sample code also shows how to set up solves on the Coordinate Breaks!
Csilla
Csilla Timar-Fulep
Hello Stephen,
Csilla
