NSC editor not showing cells
  • September 28, 2023
  • 5 replies
  • 55 views
Hi together,
With the last Zemax Version (ANSYS R2.01) I have such funny behavior of the NSC editor. Sometime (e.g. add ne object) the cell number and the whole row is not shown.
Has somebody seen that?
  • 12 replies
  • October 4, 2023
In addition I see sometime wrong index numbers for the rows which is a nightmare when working with the Merit Function.
Hi @Photoniker,
I haven’t experienced this issue yet. Do you have a way of reproducing the problem or is that random? It seems like you have quite a few lines in your NSCE. Is that also happening with fewer lines?
  • 12 replies
  • October 4, 2023
I haven’t experienced this issue with fewer lines. Indeed there are hundreds of lines. Unfortunatly we have to work with such big model to have the whole optical system. So far, I have seen this issue randomly without reproducing it. Maybe it is related to some hidden lines?!
Hard to say, anything you can tell that helps reproducing the issue might help. Does it happen always between the same objects?
  • 12 replies
  • October 4, 2023
I happen when I add a new line as shown in the screenshot at position 236.
Funny observation: If you change into the express view, it looks right. Changing back looks wrong again.
