Service Pack
OpticsViewer 23.1.02 Release Notes
Tom Pickering
March 22nd, 2023
OpticsViewer 23.1.02 contains the following fixes and enhancements.
Catalog Updates
Materials
  • The Micro Resist Technology (MRT) lens catalog has been added: 
    • New catalog with 7 materials: ORMOCLAD, ORMOCLEAR®, ORMOCLEAR®30, ORMOCLEAR®FX, ORMOCOMP®, ORMOCORE, ORMOSTAMP®.
    • MRT’s “Ormo” product line comprises organic-anorganic hybrid polymers made for optical applications. They combine high transparency from the visible down to the NIR region with extraordinary stability compared to purely organic polymeric materials. Hybrid polymers are UV-curable requiring only low processing temperatures and short production times. The products in the catalog cover different refractive indices and process compatibility.   
Test Plates
  • The Qioptiq Photonics test plate list has been added: 
    • New Test Plate list with 1451 test plates.
    • This test plate list replaces LINOS Photonics test plate list in previous releases.
Bug Fixes
  • Ray Aiming – Fixed an issue with the ZOS-API where applying the recommended ray aiming settings in the System Explorer were different from the settings from GetRecommendedSetting.
  • Optically Fabricated Hologram – Fixed an issue where Optically Fabricated Holograms would not recognize the construction file references after being extracted from ZAR.
