Boundary constraints user-extension
  • October 29, 2021
  • 710 views
Hi everyone,
When specifying custom boundary constraints, I was using the Default Merit Function as a template, moving the default boundary constraints above DMFS and making my edits there.
I created a simple user-extension to speed up this process. This user-extension creates default boundary constraints at the top of a sequential Merit Function. It uses the default values (Min: 0 | Max: 1e+03 | Edge Thickness: 0) and only creates the relevant operands. If it is an air space it only creates MNCA, MXCA, and MNEA. If it is a glass space it only creates MNCG, MXCG, and MNEG.
Small update: it only adds boundary constraints to thicknesses that are variable.
Maybe this can be useful for someone else.
yuan.chen
  • 276 replies
  • November 1, 2021
Hi David,
This is exactly what I wanted when setting up the merit function operands, Thank you so much!
Yuan
