Tried adding a new colleague but nothing seems to happen, it looks like there is a process going on but the user is not being added, I have tried doing it to multiple browsers, all having the same issue.
[Mod note: Image containing personal information was removed.]
We apologize for the delayed response and the troubles you are having. This problem is likely caused by an intermittent server issue; please try it again. If you still have problems adding another user, we can help you further troubleshoot or add the user from our end.
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
