Load FEA Data Bug
Jeffrey.Strecker
Hello community!  I have an issue where one of the FEA datasets under “Load FEA Data” within the STAR Module won’t allow me to remove it from the system.  The procedure is to right click on “mirror1_face” shown in the snip below and then select “remove from the system”.  Although after performing this procedure the dataset is still there.   I can delete any other dataset but for some reason I can’t delete this one.  It isn’t a huge deal, just annoying when trying to keep a clean file.  Has anyone else seen this bug or am I doing something wrong?
Esteban
  • July 10, 2024
Hi Jeff, I’m the PM for STAR tools in OpticStudio. I haven’t seen this behavior before and it’s obviously not expected. Can you send me an email at esteban.carbajal@ansys.com and attach the file so I can try to reproduce it? Thanks!
Jeffrey.Strecker
Hey Esteban, sorry for the slow reply.  Yes I’ll send you an email with the file.
