How can I call a ZPL macro from ZOS API?
Calling a ZPL macro from ZOS-API is not supported.
However a workaround exists. To run a macro, you can save the macro as a ZPLM user-defined macro, for example ZPL01.ZPL.
If that operand is added in the merit function, when the merit function is updated, the macro will be run.
Be the first to reply!
