"This file was created by a newer version" error message using same version
  • January 17, 2023
  • 113 views
I just installed the latest version Ansys 2023 R1.00.
While opening a session, I got the following error message:
Definitely that is a bug? How can I avoid that?
Best answer by Ethan
Hi @Photoniker,
This is certainly odd behavior. Something you can try is renaming the extension of the file. If it is a .ZOS file, try renaming it to use the .ZMX extension.
Let me know if that works.
Ethan
Ethan
  • 107 replies
  • January 24, 2023
Hi @Photoniker,
Ethan
