NSC Ray Trace for CAD object
Christabelle Tiong
Need Help
I wanted to have surface 10 as a reflective surface (like a mirror). However, when I trace the ray, in 3D, the light ray doesnt seem to reflect. Any idea why?
Hi Christabelle,
Any chance you can share this file with us for troubleshooting? The issue could be related to how this CAD file was generated. Usually, if the parts of that prism were in direct contact, I would expect OpticStudio to merge the different parts together, and not show those 45 degree surfaces (if that makes sense). Is there an air gap at Surface 10, and if so what’s the thickness of that gap? It looks like the reflection is happening, but the rays are propagated backwards somehow. In your Shaded Model, can you open the settings and tick Fletch Rays to show the direction of propagation?
  • 1115 replies
  • March 6, 2023
Hi Christabelle,
  • 102 replies
  • March 8, 2023
Perhaps it’s just the Shaded Model view settings… Have you ticked the “Split NSC Rays” option ?
Christabelle Tiong
Hi, thanks for telling, the problem has been solved.
