[ZOS-API] Can I run Standalone and Interactive Extension at the same time?
  • April 7, 2020
  • 268 views
Michael Cheng
Are you having any problem with trying to run two different modes in a ZOS-API code?
Here is some tricks for you!!
First, if you exactly need to run two mode in a code, remember that you can only have one "IZOSAPI_Application" at a time. You will need to close the previous application in one mode in order to open it.  In below, we provided a sample code.
import os
from win32com.client.gencache import EnsureDispatch
from win32com.client import gencache
if __name__ == "__main__":
    # Create Connection
    gencache.EnsureModule('{EA433010-2BAC-43C4-857C-7AEAC4A8CCE0}', 0, 1, 0)
    gencache.EnsureModule('{F66684D7-AAFE-4A62-9156-FF7A7853F764}', 0, 1, 0)
    TheConnection = EnsureDispatch("ZOSAPI.ZOSAPI_Connection")
    if TheConnection is None:
        raise PythonStandaloneApplication.ConnectionException("Unable to intialize COM connection to ZOSAPI")
    # Test for Extension
    TheExtApplication = TheConnection.ConnectAsExtension(0)
    if TheExtApplication is None:
        raise Exception("Unable to acquire TheExtApplication")
    if not TheExtApplication.IsValidLicenseForAPI:
        raise Exception("License is not valid for ZOSAPI use")
    TheExtSystem = TheExtApplication.PrimarySystem
    if TheExtSystem is None:
        raise Exception("Unable to acquire _TheIESystem")
    # Do something in Interactive Extension
    TheExtApplication.CloseApplication()
    # Test for Standalone
    TheStandApplication = TheConnection.CreateNewApplication()
    if TheStandApplication is None:
        raise PythonStandaloneApplication.InitializationException("Unable to acquire TheStandApplication")
    if TheStandApplication.IsValidLicenseForAPI == False:
        raise PythonStandaloneApplication.LicenseException("License is not valid for ZOSAPI use")
    TheStandSystem = TheStandApplication.PrimarySystem
    if TheStandSystem is None:
        raise PythonStandaloneApplication.SystemNotPresentException("Unable to acquire _TheSASystem")
    # Do something in Stand Alone
On the other hand, there is actually a potentially better solution depending on your purpose. That is, in ZOS-API, you are allowed to have multiple IOpticalSystem simultaneously. Just check the following methods!!
LoadNewSystem()
CreateNewSystem()
at IZOSAPI_Application
CopySystem()
at IOpticalSystem
Hope this is what you are looking for!
Thank you for reading!
Thank you Michael!
