ZOS-API
Hi all,
I am using ZOS-API. I want to change the temperature of my configuration from 20 degree celsius to 30 degree. In addition I also want to change the ray aiming to paraxial condition.
Is there anyone, who have used such things or any suggestions?
Hi Sanjeev,
Assuming you have a thermal configuration like so:
The following lines of code:
# Retrieve your TEMP operand based on its row number (in this case: 1)
TEMP_Row = 1
TEMP_MCE_Operand = TheSystem.MCE.GetOperandAt(TEMP_Row)
# Select specific cell (configuration) from the TEMP operand (in this case: Config 3)
Config3_Cell_Number = 3
TEMP_Config3_Cell = TEMP_MCE_Operand.GetCellAt(Config3_Cell_Number)
# Update cell value
TEMP_Config3_Cell.DoubleValue = 23.45
Would produce the following result:
In the lines of code, the important parameters are the row number of the TEMP operand (TEMP_Row), and the configuration number you wish to change (Config3_Cell_Number).
Enabling Paraxial ray aiming can be done with this line of code:
# Enable Paraxial ray aiming
TheSystem.SystemData.RayAiming.RayAiming = ZOSAPI.SystemData.RayAimingMethod.Paraxial
Additionally, the RayAiming interface has the following properties that can be adjusted:
I hope this helps. Take care,
  • 1098 replies
  • August 8, 2022
Hi Sanjeev,
TEMP_Row = 1
# Update cell value
Thanks David,
I get through.
