ZLC file not showing in stock lens matching
  • 20 June 2024
  • 32 views
I can create a private stock lens catalog from .zos files with extension .zlc. This shows up in the lens catalog list but does not show as option for stock lens matching. If I instead create the private catalog with .zmf extension (using .zmx files), it shows up as option for stock lens matching.
Are .zlc files incompatible with stock lens matching?
Don’t use .ZOS files. Stick with .ZMX. The ZOS file format was poorly thought through and implemented, and is being withdrawn in the future, I believe.
@Mark.Nicholson , Good to know! Thanks.
