worst case tolerance
  • June 29, 2023
  • 166 views
Shun
HI eyeryone
I have a question.
If I obtain the worst-case  through tolerance analysis in Zemax, how can I directly incorporate this scenario into the system?
Is there a keyboard shortcut or do I need to manually input the data?
thanks
Best answer by Chandan.Maurya
Hi Shun,
After tolerancing the best and worst ZEMAX files will be generated, you can open these Zemax files and analyze the best and worst performance respectively.
You just have to check the save best and worst files in the tolerancing setup.
Hope this help!
Thanks.
  • June 29, 2023
Hi Shun,
Hope this help!
Thanks.
Shun
  • June 29, 2023
Thanks for your help
-shun
