Which zoom configuration of my microscope has best optical resolution
  • September 14, 2022
  • 68 views
xiaoleiwang
Hi everyone,
We have a microscope with different zoom lens design (8 configurations). And the analyzed results show below.  According to Rayleigh criterion, the object side N.A. should determine the resolution: 0.61*lambda/N.A. Therefore, the first configuration with largest magnification should have the best optical resolution. correct? However, the airy disk radius should also determine the optical resolution, then configuration 4 should have the best optical resolution. I am confused why these two are not consistent with each other? And which one is right to determine the optical resolution of microscope? I think object side N.A should determine. Please let me know if I am wrong or miss something here. Any information would be helpful!
XW
Configuration Magnification WFNO Object side N.A.
Airy disk Radius (micron)
Note: this value from the spot diagram
1 0.361 9.17 0.02 6.265
2 0.322 8.66 0.019 5.917
3 0.193 7.36 0.013 5.031
4 0.138 7.27 0.009 4.966
5 0.097 7.56 0.006 5.166
6 0.07 8.03 0.004 5.484
7 0.05 8.51 0.003 5.816
8 0.04 8.95 0.002 6.113
Be the first to reply!
