What can I do if overwrite the original files that come with OpticStudio?
  • March 20, 2020
  • 307 views
Ali H
Don't worry - there is no need to panic!
If you overwrite your original files, you may retrieve them from C:\ProgramData\Zemax. They are originally placed in this location, and then some are copied over during the installation process; however, the folder by default is hidden, so you will need to change the settings in Windows:
Best answer by Mark.Nicholson
Hey Ali,
Another option, but which does not need admin privileges, is to delete or rename the version.log file in Documents/Zemax/License
When you next start OS after this, it will reinstall all the files that ship with the program as standard.
Hey Ali,
  • February 10, 2021
If your COATING.DAT is frequently over-written by ZAR extraction use RevertCoatingFile.ZPL.
# Reverts system to original COATING.DAT
my_path$ = $COATINGPATH()
my_source_filename$ = 'C:\ProgramData\Zemax\Coatings\COATING.DAT'
my_destination_filename$ = my_path$ + '\COATING.DAT'
COPYFILE my_source_filename$, my_destination_filename$
PRINT my_source_filename$ + ' was copied to ' + my_destination_filename$ + '.'
