using the function "The Convert to NSC Group tool"
  • 10 August 2020
  • 16 views
Badge
The Convert to NSC Group tool will automatically convert sequential surfaces to their equivalent non-sequential objects. It can convert most commonly used sequential surface types, surface apertures, and coordinate breaks into a Non-Sequential system. However, not all sequential surfaces have its non- sequential equivalent and hence, they cannot be converted. This tool does not replicate the data exactly, care should be taken to manually check if the non sequential design reflect the sequential design before any analysis is done.
Be the first to reply!
