user defined apertures
  • August 14, 2020
  • 610 views
If I use rec, lin and arc functions to define the below user defined aperture in sequential modelling, how do I know which part acts as aperture and which as obscuration?
Hi Divya,
The easiest way to test which region is an aperture and which is an obscuration is to place the UDA on a flat surface and trace a grid of rays. You can't really tell just from the graphic. First of all it depends if the UDA is loaded as an aperture or an obscuration: that is separate to the definition of the UDA itself. So you can 'reverse the polarity of the UDA' with that switch.
Multiple polygons may also be nested inside a UDA. If a ray intercepts a point within a polygon that is within another polygon, then the point is considered to be outside the aperture. This convention allows “islands” to be defined within apertures that become obscurations, and vice-a-versa. Any number of nesting levels is allowed, and each level toggles the inside/outside status of the point.
