Updating Merit Function does not terminate
  • Jan 5, 2022 1:14 PM UTC
  • 514 views
Dear Zemax team,
I have added a genc function into my Merit Function, maybe with some wrong parameter. Now the update of the Merit Function does not terminate (after several minutes) anymore. I have pressed the Terminate button next to Updating merit Function, but the text box with Updating Merit Function stays. I am practically locked out. I have already terminated Zemax, but when I restart and recover the file Zemax gets stuck in updating Merit Function as soon as I open the Merit Function editor.
Do you have any idea how to suppress the automatic update of the Merit Function, so that I can change the genc parameter? Or to edit the Merit Function outside Zemax? Or how to terminate the Merit Function update?
Many thanks
Markus
Best answer by Mark.Nicholson
That sounds like a bug, but to fix the immediate problem, so to Preferences, Editors and uncheck the option Update Merit Function on Load, so you at least have a chance to fix it :-)
  • Mark
  • Mark
  • Jan 5, 2022 6:34 PM UTC
Mark, thanks a lot for the help. That let me in again. I accidentally set the resolution of genc to 10, so it just kept running. Maybe the bug is, that terminate did not work.
Thanks again
Markus
