Truncated Spherical Lens: How to model ?
  • 28 June 2024
  • 5 replies
  • 146 views
Is it possible to truncate the top/bottom of a spherical lens in Zemax?
For example. I would like cut the top/bottom part of a spherical lens to produce a rectangular spherical lens as shown below.
Cheers!
You can do it with User Defined Aperture (.UDA). See p. 433 in the help pdf file.
Your file should look something like that:
LIN -0.8 0.6
LIN 0.8 0.6
ARC 0 0 73.739 30
LIN 0.8 -0.6
LIN -0.8 -0.6
ARC 0 0 73.739  30
BRK
B.R
Nadav
@Asuku
Yes, a UDA should do the trick.  Additional detail can be found here:
@Asuku
Very helpful. Thank you, Jeff.
Hi @Nadav & @Jeff.Wilde: A follow up question, will Zemax capable of producing ISO drawings of reshaped elements ?
Hi Asuku
I don’t know of a method. I am also interested in a solution.
