Transitioning across many configurations more quickly
  • August 31, 2023
  • 146 views
Awallo
I’m using OS to trace out many different optical paths at once using a lot of configurations. I’m at 18 configurations right now, and an issue I’m consistently dealing with is clicking through from looking at configuration 1 to wanting to see #17… all I know now is that I have to click the Configuration Arrow 17 times and wait as OS kind of tries to render many of the quickly passing configurations on the way to 17.  Is there an easier way to transition across many configurations compared to clicking the arrow a bunch of times?
Sorry for the trivial question, but I’m always doing it.
Best answer by Chandan.Maurya
Hi, Awallo,
You can directly go to desired configuration just by double clicking to the configuration number at which you wanted to go. Little star on the top of cofiguration number will tell you the active configuration.
Alternatively “Ctrl + A ” can be used to go to configuration one after other (this is the other way what you was doing to change the configuration).
Thankyou.
  • August 31, 2023
Hi, Awallo,
Thankyou.
Awallo
  • August 31, 2023
Ahh! The double clicking trick is perfect! Just what I was looking for. Thank you.
