tolerancing an aperture value that is in the system explorer window
  • May 2, 2024 8:43 PM UTC
  • 166 views
Hi
I would like to tolerance the aperture value using the tolerance data editor.  I heard you can use TCON.  How do I do that?
Best answer by Jeff.Wilde
Hi John,
You can define the nominal aperture value in the MCE using the APER operand, and then use TMCO to tolerance variations about the nominal value.
Here is a post that describes how to do something similar for tolerancing of a system wavelength:
  • May 3, 2024 5:27 AM UTC
Hi John,
