Answer
if my laser source has a wavelength range, how can I include that in my tolerance analysis (which operand to use)?
  • September 25, 2023
  • 175 views
icybird
Say my laser source is 1300 +/-10nm, with normal distribution 3 sigma, which operant to use to include it in the tolerance editor?
Thanks.
Hello @icybird,
I’m not sure that’s what you’re asking, but here’s what I’d do.
  1. Setup a WAVE operand in the Multi-Configuration Editor and set it to 1.300 um
  1. In the Tolerance Data Editor add a STAT operand with Type 0 (normal distribution) and #Dev 3 (number of standard deviations), and a TMCO operand (tolerance multi-configuration operand) with the Row and Config# corresponding to the WAVE operand setup in 1., it should pick-up the nominal value of 1.300 um. Then simply add -0.010 um, and 0.010 um as the Min/Max respectively
If you run some Monte Carlo runs, this is what you’d get:
I hope this helps.
  • September 26, 2023
Hello @icybird,
I hope this helps.
icybird
Hi David,
Thanks very much for the right on target answer! That is exactly what I am looking for!
