Tolerances on Abbe ( TABB )
  • August 10, 2023
  • 311 views
Christian Zimmermann
Dear ANSYS Team,
I have got a question regarding usage of  “TABB” Operand with respect to SWIR spectrum.
OpticStudio Help says that TABB is intepreted to be a change in d-light Abbe number, which will change the index at all wavelengths in a non-linear fashion.
Are there any recommendations to simulate tolerance of Abbe-number in the SWIR regime from 950 to 1800 nanometer wavelengths?
Many thanks in advance.
Kind regards
Christian
Best answer by MichaelH
Hey Christian,
First, note that the Abbe number is a very specific characterization of the slope of the dispersion curve; by definition it is measured at the FdC spectrum & represents a “pivot” of the dispersion curve around the d-wavelength.  The following article goes into more detail about how OpticStudio models TABB:
(25) Modeling Refractive Index | LinkedIn
Since TABB uses a material solve and the wavelengths for a Material Solve are between 300nm to 2500nm, you can still use TABB directly in your tolerancing.  I would suggest downloading the ZAR from the above article, change the material on Surface 1 & Surface 3, change the vd offset on Surface 3, & then refresh all the windows.  You will be able to see the difference between the nominal index (blue) and the toleranced Abbe (green) at the desired wavelengths between 950nm-1800nm.  Once you find your extreme FdC Abbe numbers that reflect your expected dispersion curve, you can enter these directly into the TDE.
Note that if you need to model refractive index tolerance outside of 300nm-2500nm, then you will have to model the change in dispersion (both y-intercept and slope) outside of OpticStudio by manually modifying an AGF glass catalog and then using this modified AGF catalog in your tolerancing.
  • August 10, 2023
Hey Christian,
