Surface tilt after reversing the path
  • November 20, 2021
  • 53 views
Hi everyone,
I encountered one problem using the reverse lens command for a tilted surface. The surface is tilted around both X and Y. After applying the reversing button, the surface cannot be realigned along its original path.
The path is in the first pic. The collimated light is reflected by a tilted surface and at the image side there’s a mirror. Then I copied the elements in the following path and applied the reverse function but the path is not the original one.
Be the first to reply!
