STAT command Vs Monte Carlo settings.
  • September 16, 2023
  • 203 views
sarvesh_space_lover
Hi, In TDE we can use STAT command to define statistics that Zemax should follow during Monte Carlo runs. But in tolerancing window also we can set the distribution. It seems from result file that Zemax follows distribution which is set in tolerancing window. (Please find the screenshot attached).
In which case does it make use of distribution defined by ‘STAT’ command?
Best answer by Mark.Nicholson
That drop box will create a STAT command that will control all the tolerances after it, until a new STAT command is issued.
