Spot size measurement in sequential mode
  • February 25, 2025
  • 64 views
Sayak
Hi, I am relatively new in optics and OpticStudio. I am trying to simulate the spot size at certain distance from a lens while using a fibre as source. Spot size changes as we move the image plane further from the lens as expected. But I am not seeing it change as I move the image plane from 330mm to 600mm. Not sure why.
Second question is when I do a quick fucus, it doesn’t bring the image plane in the focus. But when I set the Thickness cell to marginal ray height it does move the image plane to the right position. Any help will be highly appreciated. Thank you.
Be the first to reply!
