Simplified imported CAD model.
  • Jul 29, 2022 12:04 PM UTC
  • 112 views
Luca.cellerino
Hello everybody,
I would like to assign the catadioptric characteristic to a surface without drawing it in the CAD or without defining Boolean operations that would make the CAD model extremely heavy (I am attaching an explanatory image). Is it possible in OS?
Thanks a lot to the whole community.
Best answer by Christophe.Weisse
Dear Luca,
Thanks for sharing an illustration in the attached file - always easier to better understand the context.
I would recommend using Array object(s).
You can use any object as the parent object (geometry) and easily create an array of these.
You can specify different number of elements along any of the X,Y,Z axis, as well as different directions, linear or non-linear steps.
Christophe.Weisse
Dear Luca,
