Set surface for genc Merit function
  • Jan 5, 2022 1:25 PM UTC
  • 5 replies
  • 453 views
Is there a way to set the surface number for a genc/genf Merit function, as i would like to work it on an intermediate surface? Thanks
Markus
Best answer by Mark.Nicholson
Yes. Use IMSF (image surface) prior to your GENC operands to define what the image surface is. It’s a really useful operand, and you can use it multiple times so you can define multiple image surfaces.
  • Mark
  • Mark
  • Jan 5, 2022 6:34 PM UTC
Mark, great! I will try this.
Many thanks
Markus
  • Jan 5, 2022 7:12 PM UTC
Hey Mark,
Here’s a related question.  In some cases, hitting the SAVE button on a group of analysis settings forces a corresponding merit function operand to use those settings (unless explicitly overridden by one or more of the operand input values) -- a common example is IMAE.  However, this doesn’t seem to be the case for GENC & GENF.
So, is there any way to control parameter settings that are not part of the operand input? For example, “Use Polarization” and “Scatter Rays” ?
Thx,
I’m afraid that kind of data handling is added on an operand-by-operand basis. You’ll need to put a feature request in to have that kind of control (via the CFG data) for any specific operand that doesn’t already support it.
  • Mark
  • Jan 5, 2022 8:07 PM UTC
That’s what I thought.  Would be nice to have more uniformity across operands in this regard.  I can toss this suggestion into the hopper, but I’m not holding my breath for a change anytime soon...
However, on the plus side, all of the analysis options are available for control through the ZOS-API. So, if a user really wanted maximum flexibility, it looks like a UDOC operand could be implemented with a custom C++ compiled client program. Certainly doable :thinking: , but not as easy as hitting a SAVE button.
