Red box and exclamation mark popping up while inserting detectors objects
  • May 16, 2022
  • 398 views
Giulia Panusa
Hi!
I am getting a very strange error while trying to insert detector rectangles while using Zemax in Non Sequential Mode.
I am working with CAD objects, but as soon as I try to insert simple detectors, the raw gets highlighted with a strange red box:
This can happen also with the other objects from time to time:
Zemax stops working and I have to force quitting the software. When I reopen Zemax I get these two errors:
Does anybody know why this happens?
I thought it was because of the big cad files, so I tried to insert only simple detectors:
Unfurtunately I get the same behavior and I have to quit Zemax.
I thank you in advance for your help!
Cheersm
Giulia.
Best answer by Don Dickinson
Hello!
I suspect it’s a bad catalog or other file in Opticstudio’s DATA folders.  To refresh it, delete VERSION.LOG from Documents\zemax\license, and restart opticstudio. It will recopy all the default files for you.
l
  • May 16, 2022
Hello!
l
Giulia Panusa
Hi Don!
Thank you for your reply.
I actually reinstalled Zemax another time and I renamed the Zemax folder differently. By doing this the reinstallation worked finally and the software works again.
Thank you for your suggestion!
Cheers,
Giulia.
