Rectangular beam
  • August 14, 2023
  • 224 views
Hello Guys,
In sequential mode, how to design a collimated rectangular beam with different divergence angles along X and Y?
Regards
Best answer by Kevin Scales
Hi Amir,
The simplest method would be to create a single diverging beam by giving surface 0 a thickness and then place a rectangular aperture into the system with side lengths calculated with some trig to produce the desired angles in X and Y.
Kevin Scales
  • August 14, 2023
Hi Amir,
