Radius of curvature in lens data editor not automatically thermally picked up
  • Nov 1, 2021 4:03 PM UTC
  • 803 views
Monica93
Dear community,
I am very new to OpticStudio , and while a course is still pending within my company, I am trying to figure stuff out myself. So forgive me if my questions turn out to be very basic. I would very much appreciate it though, if any help is available.
I am doing a thermal analysis for my optics design. My design is quite simple:
I have an optical fiber in front of an aspheric plano-convex collimating lens:
screenshot of lens data editor
When I first set up my minimum and maximum temperatures, the multi-configuration editor opens.
There you see the configurations that were automatically created. On each line a different operand is shown and its value for each configuration (i.e., column) is given. Below is a screen shot of the system:
Screen shot of multi-configuration data editor
I was expecting that surface 3, the convex surface of the lens would automatically be changed as a function of temperature as well. In other words, in the multi-configuration editor I would have expected a line with the operand ‘CRVT’ specified for surface 3, that would give me the value for each temperature.
Why doesn’t OpticStudio does this?
The radius of curvature of  a convex lens will change with temperature, as the lens’ material will expand or shrink with a change of temperature.
Thank you very much if someone could explain what’s going on.
Monica
Hi Monica
I have checked OpticStudio behavior with the sample file called "{Zemax}\Samples\Sequential\Objectives\Even Asphere.zmx". The curvature is correctly added in the multi-configuration editor. Just scroll down :-)
Let us know if I miss anything. Thank you!
Hi Monica
Monica93
  • Nov 9, 2021 6:50 AM UTC
Dear Sandrine,
Thank you for your answer! I should work then as I expected.
Monica
