I got some problems with units and normalization with the radial grating:
Lets say my grating equation is d = 1872-9459r^1+23000r^2+…where the units are in microns.
How do I insert it with the correct units to the radial graitng parameters?
edit:
I try also grating equation with d = 0.41-3.21*r^1+12.53*r^2+...in milimeters where this series is very similiar to ~1/r, still, something is wrong...
Nadav
Hi Nadav,
I’m not sure what you mean when you say:
But this is what the Help File says about the Radial Grating:
d is the grating spacing (always in micrometers)
the Ai coefficients all have units of micrometers
p is the normalized radial coordinate defined by
where r is the radial coordinate on the surface in lens units and R is the user defined normalization radius
If your equation is already in microns, then you can just copy the coefficients into OpticStudio. I don’t know your Norm Radius and Wavelength, but I looked at your equation and found that d is roughly in the order of 1000 to 10 000 um. This means that your grating period is somewhere between 1E-3, and 1E-4 lines per um (I think the grating period is one over the grating spacing). Therefore, your diffraction angles will be quite small and hardly noticable in a 3D Layout. If I use a Norm Radius of 5.0 and use a Clear Semi-Diameter of 5.0 as well, this is what it looks at 0.55 um after 100 mm of propagation for diffraction orders +0 (blue), +1 (green), and +2 (red):
It sort of makes sense because your equation has a quadratic shape like so:
Therefore, the diffraction is closer on the optical axis because the spacing is smaller. On the edges (p = 1.0) it becomes so large that there almost isn’t any diffraction.
I tried now to insert the following series: d = 1.7e2-2.97r+2.12e-2*r^2-7.7e-5*r^3+1.56e-7 *r^4-1.86e-10 *r^5+1.29e-13*r^6-4.8e-17*r^7+7.41e-21*r^8(in mircrons red in the graph) and no matter what was the Normalziation, the grating did almost nothing.
When I use your equation, I get the following graph:
I’m assuming OpticStudio won’t like a negative grating spacing (d value), which is happening at about 270 um.
I’m using the following code to produce the graph:
import numpy as np
import matplotlib.pyplot as plt
# Coefficients
As = [1.7e2, -2.97, 2.12e-2, -7.7e-5, 1.56e-7, -1.86e-10, 1.29e-13, -4.8e-17, 7.41e-21]
# Grid [um]
r = np.linspace(0, 1500, 100)
# Grating spacing
d = 0for (power, A) in enumerate(As):
d += A * r ** power
# Plot the results
plt.figure()
plt.plot(r, d)
plt.xlabel('r [um]')
plt.ylabel('d [um]')
plt.grid()
plt.show()
This seems quite different to what you are showing, are you sure about the coefficients?
Add here a new polynom that worked[ 3.47068643e-23 -2.42712129e-19 7.17714256e-16 -1.16904982e-12 1.14551793e-09 -6.92639738e-07 2.54963018e-04 -5.39725456e-02 6.01267046e+00]-starting with A8 and ending with A0. Now it seems to work, but I think I have now problem with our model and not with zemax. I’ll update in case I stuck again.
My pleasure. The graph looks better with those coefficients indeed.
Let us know if you are stuck again :)
edit:
Nadav
Page 1 / 1
edit:
Nadav
Hi Nadav,
I hope this helps.
Hi David,
Thanks for the quick and the detailed answer.
edit: well, it’s seems to work now.
Thanks again,
Nadav
Hi Nadav,
import numpy as np
# Coefficients
# Grid [um]
# Grating spacing
d += A * r ** power
# Plot the results
plt.figure()
plt.plot(r, d)
plt.grid()
plt.show()
Hi David,
Maybe I did mistake while copying.
Thanks again for the help David,
Nadav
Hi Nadav,
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
