Polarisation in non sequential mode
  • Dec 22, 2022 9:21 AM UTC
  • 1125 views
Akhil
Hi All,
I am using a source diode which is propagating the light. The light rays pass through a laser rod from the side (cross sectionally) and the laser rod is in Z-plane(Longitudinally).
So if I want to assign TE polarisation to my source diode rays, is the following setup is right?
Thanks in advance
Akhil
Best answer by Ethan
Hi @Akhil,
The orientation of the electric or magnetic field also depends on your chosen Polarization Reference Method. The X Axis Reference is set by default since many systems use the Z-Axis as the direction of propagation. However, in your case, the rays propagate along the X-Axis so using a Y- or Z- Axis Reference would be a better choice.
When you define Jx and Jy (Jones vector components), OpticStudio uses the following definitions to compute the appropriate E fields, where Jx is along S and Jy is along P:
  1. X Axis Reference: The P vector is determined from K cross X, and S = P cross K.
  2. Y Axis Reference: The S vector is determined from Y cross K, and P = K cross S.
  3. Z Axis Reference: The S vector is determined from K cross Z, and P = K cross S.
Therefore, if we choose Y Axis Reference and we set Jx = 1 / Jy = 0, then you will have a TE polarization for each ray hitting the structure.
For more detailed information about defining polarization, please see the Help File: The Setup Tab > System Group (the Setup Tab) > System Explorer > Polarization (System Explorer) > Defining the Initial Polarization.
Ethan
Ethan
  • Dec 27, 2022 9:26 PM UTC
Hi @Akhil,
Ethan
Akhil
  • Student
  • Jan 3, 2023 9:29 AM UTC
Hi @Ethan,
Thank you so much for your response. I want to clarify about one more thing.
If  my ray travells on X-Y plane with an angle (for eg: 20° from the X - Axis and 70° from the Y-Axis), then can you please explain to me how can I assign the TE polarisation to the didode rays?
Kind regards
Akhil
Ethan
  • Jan 11, 2023 12:48 AM UTC
Hi @Akhil,
Please see this post for my answer: Polarisation defining | Zemax Community.
Ethan
